Show skip ads button for entire duration of detected ad block?
Is it possible to show the skip ads button for the entire duration of the detected ad block? It’s very easy to miss, and when manually fast forwarding through ads you no longer have the option to skip.
I am using an Apple TV as the Plex client.
Thanks!
It’s almost unusable as it is right now
Not sure how it works on Apple but on Android once it disappears if I click on the center button to bring up the pause and timeline it is at the top so pressing up twice highlights it so it can be clicked.
Don’t forget if you set it on all the time and commercials are incorrectly detected you will be stuck with it on your program so it would have some downsides if that happened.
