Show with lots of episodes disappears from continue watching
There is some strange behaviour with a TV show that contains lots of episodes, the show I am talking about is CoComelon.
Everything works fine as expected. When episode S00E163 has played the following happens:
  • The next episodes does not automatically play
  • The show disappears from continue watching
When you play S00E164 and beyond, the next episode automatically plays fine. However, it will never appear in continue watching again. If I mark episodes S00E163 and above as unwatched the show re-appears in continue watching. If i play them again it will disappear again. The issues only seem to appear when S00E163 has been fully watched.
I do not have any show with such a high episode number to test with.
I have attached my logs.
Thank You
Plex Media Server Logs_2024-01-03_19-55-06.zip (405.5 KB)
Server Version#: 1.32.8.7639
Player Version#: Apple TV: 8.29 (7486)
Check if the episodes past s00e163 have a valid “Aired” date.
This is what’s feeding “Continue Watching”, not their episode number.
You are 100% correct. The air date is missing! Tha Thanks for the pointer!
https://thetvdb.com/series/cocomelon/seasons/official/0
