Shows not being marked as watched.
I have just noticed, since the last update, that none of my media is marked as watched after viewing them. Neither can I mark media as been watched form web, iOS or Xbox clients - I get a “There was a problem marking…” error using the web interface and “Connection to server…” error from Xbox and iOS clients.
When I checked the log immediately afterwards it mentions ;-
“SQLITE3:3D3F09CB, 11, database corruption at line 68549 of [8a8ffc862e]
Mar 30, 2016 22:58:39:596 [19628] ERROR - SQLITE3:3D3F09CB, 11, statement aborts at 51: [update metadata_item_settings set account_id=:metadata_item_settings_account_id,guid=:metadata_item_settings_guid,rating=:metadata_item_settings_rating,view_offset=:metadata_item_setti
Mar 30, 2016 22:58:39:596 [19628] ERROR - Exception inside transaction (inside=1) (Library\MetadataItem.cpp:6795): sqlite3_statement_backend::loadOne: database disk image is malformed
Mar 30, 2016 22:58:39:596 [19628] ERROR - Soci Exception handled: sqlite3_statement_backend::loadOne: database disk image is malformed
Mar 30, 2016 22:58:39:599 [22496] DEBUG - Completed: [192.168.0.10:57246] GET /:/scrobble?identifier=com.plexapp.plugins.library&key=4864 (20 live) TLS GZIP 5ms 441 bytes 500 (pipelined: 3)”
Any help - much appreciated,
Richie
Database corruption is never good.
Make absolutely sure that you did not move your plex data folder onto a networked drive (like a NAS or a file server).
If you did, move it back onto a local drive. (Because moving it onto a network folder is a recipe for corrupting the database.)
Then perform a database repair or restore an earlier backup of your database.
Thanks for the info. Rolling back to an earlier database was the least painful option. Sqlite commands on windows aren’t quite the same as the OSX ones in the ‘how-to’ so I couldn’t figure out how to do a repair…
Thanks again,
Richie :)>-
There is a SQLite extension for the Firefox web browser which is also usable for the repair operation. I used it myself twice already.
Basically it is just:
  1. export database as a csv text dump
  2. import the database back from the dumpfile
all of which can be equally achieved with a mouse instead of commands in a text console.
