Alright, I have 43 TV Shows in my plex library. 39 of those are 100% fine after editing some of the files. But 4 shows will not show all the seasons or all the episodes. I have renamed files according to this page >https://support.plex.tv/hc/en-us/articles/200220687-Naming-Series-Season-Based-TV-Shows<and I have even visited the TVDB website several times trying to figure it out. The shows I have trouble with are:
Avatar: The Last Airbender, on this show it will only load one episode from Season 2 and four episodes from Season 3. I have all the episodes from all the seasons in the exact same file format as most of all my other shows (yes im pretty sure its not a format issue because everything is either MKV or AVI and some of both work fine in a lot of shows)
Justice League/Justice League Unlimited - so on this one I have five seasons, two of JL and three of JLU and on The TVDB it lists it as JLU 5 seasons. I tried that and it only loads the first two seasons of JLU and lists them as JL.
Smallville - I have all 10 seasons but it only pulls up the first episode of each season
Spartacus - It only pulls up Seasons 1 and 3. I have Season 2, I also have the episodes of Gods of the Arena in a folder titled specials. Which is what the above website recommended to do.
Anyone who has any of these 4 shows and who was able to get them to work and has any feedback, it would be much appreciated.
Please post the actual names (copy/paste) of something easy such as Smallville. From there it will be easy to determine what the problem is.
I use FileBot for all naming. It performs the internet lookup as part of the matching process and assists with ambiguity resolution before performing renaming/moving.
All media is stored on my NAS in /media/movies, /media/tv, etc.
The naming rules used, which Plex has no issues matching, are:
Even if you corrected the naming, you must use a last step to clear the connection between the show's files, their hash value and their wrong identification.
@lloydpfX said:
Hey folks! Did this ever get answered? I have the same issue and I am wondering how to fix this issue.
Is this issue with the same show The Last Airbender?
We really need you guys to post the name of the file so we can see if its named correctly.
it should be named like this:
TV Series
----- Avatar- The Last Airbender
---------- Season 01
--------------- Avatar- The Last Airbender - S01E01 - The Boy in the Iceberg - HDTV-720p.mkv
