Hello,
Can you add a shuffle play for an entire library in Carplay Plexamp please, a one click button to play random music is the missing option to be perfect.
Thanks !
Hello,
Thanks !
Simply create a smart playlist which is so broadly defined, that it contains the whole library. Then shuffle that.
Plexamp should automatically create an “All Music” Smart Playlist for you during the onboarding steps. As Otto mentioned, from this you can shuffle that playlist in Plexamp and voila, entire library shuffled.
Yes, thank you.
