READY TO UNINSTALL
I’m really sick of PlexAmp playing music when I get in the car, get out of the car, or hang up the phone.
I can’t tell if it’s PlexAmp or some Samsung/Android nonsense. I can’t find any setting that makes it STOP!!
VLC does the same awful thing.
Ideas before I delete this terrible player?
Try turning off the Android Auto setting called “Start music automatically”
I have Android Auto turned off completely. I hate it so much.
Nothing to do with Plex, its a setting in Android Auto.
Maybe a Bluetooth setting?
Also try stopping playback altogether (in plexamp long-press the play/pause button) as this should stop anything from being able to resume playback
I recently got a 2018 Lexus and was annoyed by this as well. There is no Bluetooth setting on the vehicle to turn off auto-play on connect. I did however find a solution for me which involves my iPhone. I know nothing about an Android phone solution.
On the iPhone use the ‘Shortcuts’ app to create a ‘Bluetooth Automation’ shortcut.
- Go to Shortcuts app → Automations and create a new Automation.
- Select Bluetooth, choose your vehicles bluetooth ‘Device’, then the ‘Is Connected’ option and set ‘Run Immediately’ and hit ‘Next’
- Select “New Blank Automation”, then scroll right to select the show ‘Media’ actions.
- Scroll down to ‘Playback’ actions and select ‘Play/Pause’, then select the ‘Play/Pause’ action itself and select ‘Pause’ from the dropdown.
- Select ‘Done’ to create the Automation.
You should now have an Automation that will ‘run immediately’ when connecting to your vehicle Bluetooth and perform the ‘Pause’ function. Sometimes there is a blip of audio before the Pause is performed.
This works for any active audio I have on my iPhone at the time (e.g. Plexamp, podcasts, any other audio app on the phone). Hopefully this helps iPhone users who are also annoyed by auto-play.
