Hi all,
This is my first post. Let me know if I haven’t provided enough info. Have referred to the search results to see if this has been shared before.
Normally I sign in via my Google account. However, I’ve just gone to log in that way and clicking on the Sign in with Google button does nothing. The Facebook/Apple options work fine if you click on them as does logging in directly with a username and password.
I have tried this on 3 different devices using normal/private browsing and it seems to be consistently unavailable.
Anyone else having the same problem?
Thanks in advance.
P.
Popup blocker? The sign-in opens in a separate window.
Thanks for taking the time to reply.
Doesn’t seem to be that. When you hover over the button the cursor doesn’t change like it normally does, or as it still does for the Apple/Facebook sign in options. It’s like the button itself is broken. I can still sign in to other accounts using Google log in.
It’s the same if I try to create a totally new Plex account. I can do that using Facebook/Apple connection options or via specifying an email address but the Google option doesn’t work. The button isn’t appearing as a button, the cursot doesn’t change when I hover over.
Such a behaviour occurs if parts of the web site code get filtered or suppressed.
Look to your network operator, web browser add-ins, anti virus software, or other filter mechanisms.
I’m having this problem my self
