Web shows that Alexa is playing to a Device, but the device (Sonos Beam) is silent. Doesn’t really matter, have some Sonos One SL-s and they are silent aswell.
Edit: Alexa command is executed on the same device.
I don’t think Plex’s Alexa skill can play to a Sonos device. Music will by default play on the Alexa device itself. Do you have your Alexa device linked to the Sonos speaker and trying to play that way?
I don’t know how Alexa works on the Beam, but I’m wondering if it is outputting to the TV and not through it’s internal speakers. Have you tried disconnecting the Beam from the TV and see what happens?
Beam is a soundbar, therefore it does not output sound to TV, it outputs TV sound via its superior speakers.
So I tried it with Sonos One also. Same deal. Best case scenario is that it creates a stream on the server, the speaker (Alexa part) knows that it’s playing something, but there is no sound.
The Alexa command is very specific “tell Plex to play Pink Noise on repeat”. In my library I have a track called “Pink Noise”, which is 8h long, encoded in MP3:
Right and that’s what happens when you play something on the TV, the audio goes OUT from the TV through the ARC port IN to the Beam. I just don’t know what happens when Alexa kicks in. Now that the source is the Beam and since it is connected to the TV, the TV may interpret that as input. Like I said, I don’t know how the Beam actually works. Can you try disconnecting the Beam from the TV and see what happens then?
Checking your video, I see what you’re doing now. I tested that playing to my Echo devices and it worked. I don’t have any Sonos devices or other Alexa built-in devices to check. I’ll pass this along to the team to see if someone else can reproduce.
I have just bought Sonos kit - an arc and sub - when i ask Alexa to play something from plex she says she’s going to play it, but then silence. No stream is started on the server. Very disappointed. It says here Getting Started with Alexa Voice Control | Plex Support that Sonos is supported.
Btw I also have Amazon Echo and FireTV devices. Alexa works with Plex on these devices. Also works on my phone.
I did a dump of my logs which I can provide it it helps. In Plex Media Server.log I see the following error:
May 25, 2021 16:50:43.734 [0x549fd430] ERROR - Unable to find client profile for device; platform=Alexa, platformVersion=, device=Alexa, model=
Also I noticed that sometimes a stream appears in the Dashboard on PMS, but other times it doesn’t. Never does my Sonos actually play anything though. :-/
So the workaround seems to be that I need to rebuild my library with the loudness analysis switched off. It sounds like it’s a bug at the Sonos end - given that other clients can play music fine via Alexa. Can a plex dev please confirm??
I’m not sure Echo devices use the loudness tags at all either. I’m going to ship a release that strips them from the stream. I’ll reply when that is out and have you give it a shot.
