Silverlight
Does Plex support Silverlight?
Simple enough; does Plex support Silverlight at all?
The norwegian national broadcaster has Silverlight as an option to the windows media streaming. If possible it would be rather nice to write a simple plugin.
Yes, if the Silverlight browser plugin is installed Plex will be able to use it :slight_smile:
I have been pulling my hair out trying to find out how to install the Silverlight plugin so that I can use the Netflix app. Where are the instructions for this and/or how do I do it??
I have an Intel Mac Mini running Plex.
THANKS!
~Dubhead
Silverlight is a browser plugin, not something you need to install from within Plex. Follow this link:
http://www.microsoft.com/getsilverlight/get-started/install/default.aspx
