Hello all,
When manually entering artists in the Similar Artists tag, the tagged artists are displayed as expected in the web app until a refresh occurs, at which point they are removed from the tag. All other metadata appears to remain untouched.
Any help or suggestions is much appreciated.
Thank you.
Version 1.4.3.3433
Synology NAS model DS1513+
Current DSM version: DSM 6.1-15047 Update 1
Make sure the Lock is engaged after you make your changes. If the lock icon is not orange, your changes will be overwritten on the next refresh. Engaging the lock is supposed to prevent that.
Thanks so much for your response.
Indeed the lock is engaged, but the tag is still cleared. The orange lock still shows as engaged after refresh with the empty field.
Bumping this as it is still an issue.
Server Version: 1.13.2.5154
Web Version: 3.53.7
DSM 6.1.7-15284
