Similar artists keeps repopulating
I dont want Plex populating the Similar Artists section in mt music.
I keep deleting it, it keeps repopulating. I’ve made sure the library is only picking up personal meta data. I’ve made sure the lock symbol is enabled when the field is empty.
It’s not consistent either. It populated some artists one day, leaves them blank another.
One particular artist it has just populated with wrong suggestions because it incorrectly identifies the artist, called Sky, as an electronic group, so it gives totally incorrect suggestions.
What am I doing wrong?
Keith
How?
There is only one way to achieve this. And these settings need to be made before the first artist is added to the library:
That’s a tough one, because:
Try ‘Fix Match’ on the Artist level, if you don’t want to totally re-create your music library.
The how is a good question. And, probably my mistake. It’s not so straightforward knowing enough about Plex before you populate he library. So, it looks like I’m stuck with what I’ve got. Not to worry.
I’ll try the Fixmatch on my rogue artist.
Thank you
