I'm sure simon will get everything worked out in time.
He hasn't been working on this client very long really and this type of thing takes time to get all the kinks and bugs out.
If you ask me he has accomplished a lot so far for the amount of hours he has put into it.
We must remember he said himself his time is limited due to family and life itself, he is not working on this around-the-clock.
I'm sure in the end everything will be just the way he wants it.. All good :)
Cheers!
Thanks ... I am taking the next few days off to enjoy what's left of my holidays :-)
A quick look at the samsung web api and it appears to be somewhat different from LGs ... i.e a fairly major rewrite of code to get functioning on LG ... I only had a quick look though so could be wrong ...
I will stop at his place today and try your app there.
I hope it will at least find the server. This didn't succeed last time I tried it, nor did the other non-LG apps.
I will give feedback later. Also on 3D-support.
He also has to run PMS on windows-XP if he wants to use medialink. If he runs it on the same system with Windows 8 (dual-boot) it will not find the server 9 times out of 10. I tried all the different suggestions that were given on this topic, but never found a way to reliably get that working. Strange, because at that same time I am able to run media from his Plex server from a different location using myplex.
I have a feeling your App is already at a stage that is surpasses medialink on every level.
3d most likely won’t work just yet as. I haven’t built in options to select it …the integrated media player requires all the ui and options to be manually created, which I am still working on.
3d most likely won't work just yet as. I haven't built in options to select it ...the integrated media player requires all the ui and options to be manually created, which I am still working on.
Had some free time this evening so new release available at http://plex.h3consulting.net ... mainly feature additions to the new player and an ability to set the clock to 24 hour time
So rewind is not possible in the LG player (just slow motion or speed up/fast forward) ... I am thinking of just seeking back a certain amount of time when the rewind button is pressed ... thoughts?
anyway one question for SImon is your code somewhere in git or SVN? I have some free time and i think i could help you with some small fixies
I have answered this previously ... an older version is on PLEX, but not this one ... I want to get it to a level I am happy with before I release it to GIT etc ...
