I have the free version of PMS running on Windows 10.
If you have the choice between several CPUs which have comparable CPUmark scores https://www.cpubenchmark.net/ as a whole, compare their "single thread rating"s.
You want the CPU which has a higher single thread rating.
see also What kind of CPU do I need for my Server? | Plex Support
The overall score isn’t really a good indicator, as one that has a far stronger single core or multi core score can end up with the exact same overall score.
Hence why I wrote:
Ah, missed that.
Single core it is. Thank you.
That doesn’t mean that single thread rating is the only thing to pay attention to.
To be able to transcode H.265 streams or downmix DTS-HD MA Atmos audio streams, your CPU needs to have plenty of overall passmark rating score. So aim high, particularly if you store Bluray “remuxes” and /or 4K material.
