Sleuth channel missing from LiveTV linup?
Server Version#:
Player Version#: 4.143.0
Tuner Make/Model:
Guide/Lineup name: Sleuth TV
Using XMLTV?:
Channel number/Name: Sleuth
I’m not clear if you mean from your tuner or a streaming channel.
If from your tuner then I would need to know the channel number and your postal code to report it to Gracenote.
If you mean our streaming channel, we may not have the rights to stream it anymore so had to remove it, but I will need to confirm with our streaming team when they are around.
Confirmed partner shut down that channel
My apologies, I guess its on the streaming service, I had the Sleuth channel saved in my LiveTV favorites section, and one day a week ago or so, it just says “it appears Plex channel is offline” but the other channels in my favorites are still there so maybe it is a licensing issue
so, to expound on this, does this mean the Sleuth channel is gone totally or just on Plex?
I guess they will fix all the hits on searches that are linking Sleuth channel to Plex currently?
That I do not know. But I cannot find anything but a youtube channel ( but I have not personally ever watched it do this might not be the same thing ) https://www.youtube.com/@SleuthChannel
I would guess google has all that cached so I would expect it to go away sooner or later but I don’t know when.
