slideshow
play music during slideshow
Hi
thanks for the great plex 9 this is fantastic!!!!
I have one question after playing around with the many features it has:
What I am looking for is to have music (from a specific folder) running when I start a slideshow.
Is there any way to have this installed. I look at all the skins out there and I only found a main folder (background music) which will play when plex is running but no other task.
It would be perfect if it would be possible to use this folder, copy a cpuple songs into it and as soon as you start a slideshow in the pictures section the music would also start to play
itself. Or at least change the string so the music is only on when going into the picture folders.
Thanks for all the nice work and please keep on adding the nice little things.
Respect!
Mattbalu
I was looking for this and lots of people ask the same without answer.
I found a simple way to do this :
1- Use google chrome , add Google Cast extension
2- make a music playlist
3- make photo playlist (slideshow)
4- play music playlist , play photo slideshow
5- send them to any tv using the extension
Simple , only 1 thing , full screen is not 100% full screen.
i hope i help someone.
