Smart collections no where to be found
Server Version#: 1.22.3.4392
I do not see Smart Collections on my sever. I’ve restarted my server and tried the steps found online and it is not there. Nor is the publishing collections to home feature. What gives?
Plex Media Server 1.22.3.4392 is now available to everyone.
NEW:
(Collections) Added support for creating Smart Collections
(Hubs) Support for publishing collections to home and recommended pages (requires Plex Pass)
I’m having the same issue, can’t figure out how create the Smart Collections. I have looked at the online documentation. When I got to create a filter and the go to Save As. Smart Collection option is not available.
Same here. Just updated, both server and web client are at/above the required version. No Smart Collection option in the menu.
You need to click filter and scroll all the way down and select advanced filters. You’ll need to use plex.tv/web to get that option.
restart your server if you don’t see it.
I have restarted the server three times already before posting here.
Are you using https://app.plex.tv which is web 4.56.3? It won’t work with the local one via IP which is not updated yet (is 4.54.5)
Thank you… plex.tv/web was what I needed to use.
That is what I was missing…thank you.
