Smart Keyboard Folio doesn’t work on iOS 14.2 Beta with Plex 7.6.1
Server Version#: 1.20.2.3343
Player Version#: 7.6.1
On my 11” iPad Pro using the Smart Keyboard Folio, I can no longer use the keyboard in Plex. I often use the spacebar for pausing and the arrow keys for skipping forward/backwards.
Same here. Also running an iPad Pro 11” with smart folio keyboard and none of the keyboard shortcuts work with Plex on iOS 14.2 beta 2.
Still an issue on 14.2 Beta 3
FYI, just did an IPSW restore of 14.1 which was released today and the Smart Keyboard controls are working again in this version. I’ll be avoiding 14.2 until I know this feature has been fixed.
@BuBubbi please report your experiences as well for everyone to see. Thank you.
Hi all,
iOS 14.2 was released today. Is anyone able to test and confirm if the Smart Folio keyboard controls work in the final build? I am unable to downgrade back to 14.1 for a while and don’t want to risk losing the controls again right now.
Thank you!
Hi there.
Sorry. I totally forgot to respond.
I am on the developer GM of 14.2, so the same version as the one released to the public today and the Smart Folio keyboard works with Plex again.
I’m currently running Plex Beta 7.9 (22079) and I actually believe it works with the previous two Plex beta versions also.
Thanks for responding. I’m on the public release of 7.9. Any idea if that build is working correctly with the keyboard controls?
I can confirm that it does work with the public version from the AppStore as well. I just tested it. You can pause with the space bar and skip with the arrow keys. So I think all keyboard commands work with Plex again. :slight_smile:
That’s great! Thank you so much for confirming this.
