Server Version#: 1.42.2.10156
Player Version#: plexamp v4.12.4
Server as a container under linux mint.
I created a Music Smart Playlist in the PMS web gui and get less results than I expected, 9 tracks. The criteria is a song title contains a string.
then i go to plexamp, and filter tracks with the same criteria. I receive 5 results, none of them the same as the 9.
Based on my filter criteria, I should receive 14 tracks.
I’ve restarted the server. It’s just odd behavior and I’m not exactly sure if there’s anything I can do about it.
Thanks in advance. Any additional info I can provide, just lmk.
Which criteria are these? Please list all of them.
Do you use the same plex user account on both devices?
The Criteria is this simple:
Match all (or any, didn’t change results) of the following:
Track Title - contains - I Can’t Make You Love Me
Same user account for both.
so they’re both smart playlists. here’s screen snips for both results from the web gui.
Note: even though the playlist created in plex GUI say 8 results, it’s actually 9.
Plex GUI
Plexamp
in the top line, switch Albums to Tracks. You want tracks as a result, not albums.
Sure, I’ve tried that, it doesn’t change the results though.
It’s still 9 tracks for the smart playlist created in GUI, and 5 tracks for the smart playlist created in plexamp.
edit: no overlap of tracks either /shrug.
2 edit: I originally created the playlist in the GUI, but because of the filter not picking up some tracks it should have, I sanity checked myself in plexamp, with unexpected results lol
I can recreate the issue on my server. I have filed a bug report.
thank you sir, appreciate your help here
