This is primarily related to Music, but I assume it’s applicable to video as well…
Plex Server version (Synology) = 1.19.4.2935
Plex Web version = 4.36.1
There are multiple Plex clients that can rate in half star increments (Plex on iOS, Plexamp on iOS & Mac are the ones I know about). In the Plex Web client, you can create smart playlists with ratings for Artists, Albums, and Tracks. However, there are issues when trying to filter items rated with half stars. The current UI only lets you choose [ Is, Is Not, Greater Than, Less Than ] with [ 0, 1, 2, 3, 4, 5 ] stars. For example, suppose I have a track rated at 3.5 stars, and I want to make a smart playlist that has all tracks with a rating of 3 or higher. So I make a smart playlist that has the criteria of “Track Rating Greater Than 3”, but it only includes whole numbers (ratings of 4 or 5, not 3.5). And because criteria that involve Ratings can only be ANDed together, there’s no way to indicate “Track Rating Greater Than 3 OR Track Rating Is 3”.
A couple ways this could be solved:
Add new rating criteria operations for “Less Than or Equal To” and “Greater Than or Equal To”
Change behavior of existing rating criteria operations such that half ratings are included (so that >3 includes 3.5, 4, 4.5, 5); and likewise for less than. This seems to be a bug?
Ideally made as part of #2, but allow selection of half ratings within Plex Web, so it’s consistent with the Plex clients.
I kept feeling like that I’m missing something obvious here (please correct me if I’m wrong or there’s another way to handle this!), but after trying several scenarios, what I ended up doing to removing all half star ratings (I had just started rating music), but that seems problematic, unless there was a server switch to disable half-ratings completely, so that in the clients that currently support it, its no long possible to add one.
Thanks!
