Smart Playlists for Podcasts
Server Version#: 1.21.2.3943
Player Version#: 1.27.1.1571-2fface66
Hello,
This is my first post here, please be gentle. :slight_smile: I’ve Googled for this but have only found one post that was closed with no replies.
The issue I’m having is with Smartplaylists for Podcasts. I’ve selected the filter to only show unplayed episodes and saved it s a smart playlist. The playlist shows up but it’s empty. I"m not sure if this is a Plex issue, or if I’m doing something wrong as I’m relatively new to Plex.
I’ll appreciate any insights.
Thanks,
Which Plex app did you use the create this playlist? Because normally, you are not able to add podcasts to playlists at all.
I’ve used the player version listed above. And also the Android version 8.11.0.22186
I just tried to recreate and there is no way to add podcast episodes to a playlist. In both Plex Player for Windows and Android mobile.
I stand corrected about the Plex player on Windows. I can’t make a playlist for podcasts just as you said, however, I can on the Android mobile app. See the screen recording here:
EDIT: Well, I guess you’ll be able to view it once google finishes processing it.
