Create Smart Playlist option missing?
The “create smart playlist” option seems to be missing from my plex web app. Not sure where it went or when. I haven’t created one in a few weeks or months and now I can’t find the option anywhere.
When I created a filtered movie search and select the + button it I get “add to collection” or “add to playlist” plus some recent playlists listed. If I select “add to playlist” I get current playlists or I can type in a new name and hit “create” but it won’t be a smart playlist. I used to have a “create smart playlist” option somewhere.
Can someone point me in the right direction?
Thanks!
Player Version 4.66.1
https://app.plex.tv
Those options used to be there but I can’t find them now.
(Not sure how to get a screen shot that you can read better but my plex web app does not give me the options that are in your screenshot)
I just can’t find “save as” anywhere!
So I just discovered that all of my previously created smart playlists (which I had for many months/years) are empty when I actually click on them. I tried rebooting and restarting everything and it is still doing this.
It’s only the smart playlists that are empty.
Ok. I finally found how to do the smart playlist. I have to create one and then filter. I was filtering first. Still not sure why previous ones are now empty. They weren’t last time I looked (last week)
It shouldn’t be that way, but sorry, I don’t know what to suggest. Maybe Otto or one of the Ninjas will step in.
Which web browser are you using?
Any browser add-ons installed?
Have you tried my link above?
I’m using Vivaldi.
I did try your link.
I have one add-on (aa advantage shopping)
