SOLUTION: Conversion failed. The transcoder exited due to an error
The Answer;
Delete your codecs folder and reboot the plex server
I have the same problem described in this topic. It is a very long topic, i haven’t read all comments yet but so far no resolution yet.
Discription: I have a raspberry Pi running Ubuntu with plex mediaserver, i’ve connected an external SSD for storage. This works like a charm with my android bases Philips TV, i’ve installed the app there directly on the OS of the TV. I can play 4K movies/series, everything. With my chromecast wich is connected with a wired connection i get the error, i stream this from my IPAD. I’ve extracted the logs, could somebody take a look and see what is going wrong, i can’t find the issue.
I also have the same issue , on windows 10 on some files.
I’m also running into this as well on basically every 4k file, and maybe 1/5 other non-4k files. Windows 10, latest Plex.
I only encountered this issue up until today. Never been an issue…
It did occur to me that i did recently add in a preroll. I removed the file path and disabled trailers in the 'Extras" settings menu, the transcoding error stop occurring.
Not sure if it has something to do with the preroll?
Mac OSX, Plex uptodate.
Does anyone have an update on this? I have been having the issue for several weeks thinking it was my machine but I devoted more resources to the transcoding and nothing. Attached are the logs yesterday was my most recent issue.
Plex Media Server Logs_2020-03-30_09-09-23.zip (3.9 MB)
I have been having the same problem. I can play files in the plex web browser, but when using the plex app on Apple TV it give issues, even with files I was previously able to view. I have attached my logs. Please help.Plex Media Server Logs_2020-04-02_11-25-30.zip (2.6 MB)
Please the same problem here, in spanish: “La conversion fallo. El transcodificador salió debido a un error.”
Plex Media Server Logs_2020-04-17_20-08-11.zip (3.2 MB)
Running Plex Server 1.19.1.2645
Windows 10 kb4549951
I’m getting this error while trying to play s01e04 of The Boys tv show.
Can’t play it in the server’s web player, can’t stream it to chromecast, can’t stream it to Android app…
This only happens with this single episode. I have been using Plex for a while and hadn’t had any problems up until now - it’s like this particular episode has something special in it that prevents Plex from playing it.
I am also successfully able to play the episode with simple VLC player, so the episode itself is fine.
Restarting Plex Media Server and even the PC doesn’t solve it.
Please suggest
@m_dzhigarov_gmail_com - You are getting an error on the .srt subtitle file, which then causes the transcoder to fail. If you are using subtitles, would you try playing without them just to see if it works? Also, try doing a “Refresh Metadata” for the entire show (thanks to @OttoKerner for this approach) and wait A LONG time. In this thread it took until the next day for it to resolve. Your error is slightly different, but worth a shot.
Apr 17, 2020 20:06:19.678 [7496] ERROR - [Transcoder] C:\Users\PC\AppData\Local\Plex Media Server\Cache\Transcode\Sessions\plex-transcode-50yegwklduwpdjowgwqfofhs-88bd4436-0b5a-4a4e-a647-a9173ce25e2c\temp-0.srt: Invalid data found when processing input
Apr 17, 2020 20:06:19.698 [0736] DEBUG - Jobs: ‘C:\Program Files (x86)\Plex\Plex Media Server\Plex Transcoder.exe’ exit code for process 2068 is 1 (failure)
Apr 17, 2020 20:06:19.698 [6608] DEBUG - Using default transcode duration of 120 minutes
Apr 17, 2020 20:06:19.698 [3240] DEBUG - Streaming Resource: Terminated session 0x52e6c78:fdabfxhrubllhq4dueuvxmhn with reason Conversion failed. The transcoder exited due to an error.
Thanks you @hokierulz ! Disabling the subtitles fixes the issue.
I refreshed the metadata and will wait till tomorrow to try again.
I appreciate the help!
Thanks Bro,
This solved my issue:
“In your case, it appears that the transcoder has detected invalid data in the srt files - for these movies”
Also, as I have other files with same issue, I supposed to Turned Off “Default Subtitle” from Settings to avoid initial transcoding errors caused by SRT files.
Great analyse, thanks!!
Plex Media Server Logs_2020-06-11_23-57-16.zip (5.6 MB)
Plex Server: 1.19.4.2935
OS: Windows 10 Pro x64 Version 1903 OS build 18362.900
So, I’ve gotten some questions from friends of mine who use my Plex server to binge movies and series. Transcoder exited due to an error, over and over again. Then I started noticing it too, on my phone, my Xbox, my parents’ TV, and their computers. Not sure if it happens while trying to watch Plex through the app installed on the same computer as my server, though. I haven’t tested that, because why use Plex on the same computer where all the files are located?
The computer is hooked up to a router through cat5 cable, I’ve got a stable connection. Haven’t noticed any dropouts or anything in a while. Though the only way I monitor it is to see if my IRC client drops out or not.
First it only happened once in a while, then it started to happen more often, and now I can hardly watch a show without it happening. Either after some seconds, some minutes in, or about halfway through. It seems really random, to be honest.
It just happened now while watching an episode of Criminal Minds. S07E18.
And lately it has started happening with music as well. So everything I use the server for.
I’ve tried turning off automatic subtitles, but that didn’t help. Not that I’m using subs much, anyway.
Anyone have any ideas?
Do you happen to have over 4,000 movies in your library? I’ve been having the same problem for months. It’s apparently an issue with an update plex made to curl. Plex knows about it and it’s been going on for awhile now but… I’m not sure they’re doing anything to fix it. I know several people that have had this issue.
Why yes, I do.
And about 13k episodes of different series and 245k tracks of music. :stuck_out_tongue:
guys i got same problem, this solution fixed it for me: An error occurred while attempting to play this video. Please try restarting both the Plex Media Server and this app
This is exactly my problem since yesterday, but I do not have over 4000 movies. It’s starting to happen more often and often and, like you, I cannot watch more than 5 minutes of anything without a transcoder error.
Maybe somebody can connect my post with this? Permanent Transcoder error since update
Whilst up to now I have only seen the issue on large movies libraries, in your case the problem arose when scanning this music library G-mp3 which has over 7000 albums
Jun 11, 2020 23:55:25.520 [7128] DEBUG - Scanning G-mp3 using en(Plex Music Scanner) with 147229 current media items and 1 section locations in the database...
Jun 11, 2020 23:55:25.879 [7128] DEBUG -   * Scanning G:\
First error was logged for the scanner at
Jun 11, 2020 23:56:09.355 [7128] DEBUG - HTTP requesting PUT http://127.0.0.1:32400/activities/88728197-2898-404b-a576-ec9ebeaf3fd6?percentComplete=%2B0%2E065260388&subtitle=Lyre%20Le%20Temps
20359 Jun 11, 2020 23:56:09.364 [7128] ERROR - Error issuing curl_easy_perform(handle): 7
Jun 11, 2020 23:56:09.364 [7128] WARN - HTTP error requesting PUT http://127.0.0.1:32400/activities/88728197-2898-404b-a576-ec9ebeaf3fd6?percentComplete=%2B0%2E065260388&subtitle=Lyre%20Le%20Temps (7, Couldn't connect to server) (Failed to connect to 127.0.0.1 port 32400: Address already in use)
and after that the transcoder failed with logged tcp error -138
Jun 11, 2020 23:56:33.192 [8428] ERROR - [Transcoder] [tcp @ 008a4e00] Connection to tcp://127.0.0.1:32400 failed: Error number -138 occurred
I have added this to the currently open issue for Movies scanning
You could try splitting the library up into 3 libraries with max 3000 albums in each ? The issue may still arise if periodic scanning is used and they are scanned quickly in succession. You can try it out. The issue should not arise when library changes are detected as it is unlikely that all 3 libraries would get updated at the same time.
Having the same issue. 3200 Movies 33k Episodes. Interesting is that within my network in my Apple TV i never had any errors coming up that the transcoder failed. But friends on Safari, Opera App, Samsung TVs, even on the Plex Player for Mac have contacted me to investigate the issue. Keep us updated about progress please.
Thank you
i have added a post to your forum thread
Once the windows tcp pool is exhausted, need to wait 5 minutes or so of no scanning for the used ports to go back to the pool. Or it may be safer to reboot windows
