Google assistant used to show me options to play media I had within plex. For example, if I said a movie name, it would bring up a panel showing the movie into, with options to play in different apps - “trailer on youtube”, “purchase on google play store”, “play on plex” (if it was in my library).
Plex is now missing from these options. Can anyone else confirm they also have this regression? Any solutions?
Solution found:
After the latest shield experience update, plex app was turned OFF as searchable … quick change in settings and results are now being listed again in results.
How did you turn Plex’s search ability back on?
Can someone tell me how to turn this back on?
Was going to make a new thread about this
Ok so nvm, i figured it out.
For future refference its in settings>google>searchable apps
Mine is on in searchable apps and still brings up nothing for Plex.
