Hello
i’ve read many topics concerned debian : most of them explain how to upgrade the server but I don’t find how to install Plex media Server on Debian.
When I clic on
the linux version is for ubuntu or others distributions but not for debian.
where can I find information about installation ? where can I download the version for debian ?
I’m a beginner in Linux Word.
I have choosen Debian because I want to see if I am able to install PMS on Debian before buy a rasbperry Pi (I have seen we can install Raspbian and then PMS). So before to buy the little computer, I 'd like to discover linux word
Many thanks for your help
and sorry for my poor english … i’m french !
I am not very well versed in the Linux world (and am a beginner as well). However, Ubuntu is based on Debian, so you could try using the install for that distro to install on your sever.
Worse case I can see is that it will not install or you need to re-install Debian (not necessarily a bad thing as it gives you practice installing it).
@drmagoo : i’ve received my Raspberry Pi ( model b+) yesterday. i’ve installed Noobs and then Raspian.
Then, i’ve installed the application ntfs, and i’ve plugged my hard drive (ntfs). I’ve also follow your instruction for armv7 on the page https://dev2day.de/plex-media-server-arm/
all seem to be ok. I can launch PMS (http://localhost:32400/web/)
But I have a problem : when I create a library on PMS and add a add a folder with 2 movies : /media/pi/FILMS/test
it scan the folder but find no files !
i did several tests but it’s always the same pb : no movies are detected
can you help me please ?
I can give you a screenshot but I don’t know how !
/etc/fstab is only writeable by root. So also a sudo leafpad /etc/fstab allows you to edit this file in the GUI if you do not have any experience with the terminal editors.
