Correct option name is “sound feedback” (sound return was a bad translation I made since my UI is not in English).
You can find this option in your Plex Media Player interface as you can see here : https://support.plex.tv/articles/115000473213-settings-plex-media-player/
Just wanted to add for future reference:
Sound feedback was unchecked on my device but no sound.
I went back to audio / device and changed from hdmi 1 to default (alsa) (figured I might as well go through all options) and now it works!!! Info still says spdif passthrough but doesn’t matter as it works!!!
=) happy days
@zeroboo said:
Just wanted to add for future reference:Sound feedback was unchecked on my device but no sound.
=) happy days
This was so helpful!
I had exactly the same problem and couldn’t work out why I was only getting 2 channels.
Thanks for the tip! Worked like a charm for me too.
Hi, I’m having similar issue using qnap ts-453be with hd station 3.2.10 and PHT 1.4.2.100
I’ve unchecked navigation sounds off, restarted hd station and pmp too
Unfortunately, I cannot see the default (alsa) option in the audio output device, the only thing I can see is:
- built-in audio (pulseaudio)
- built-in audio analog stereo (pulseaudio)
- defaults (pulseaudio)
Passthrough output device:
