I only have this issue with a select number of files. I haven’t found the common denominator. Maybe some example media info’s can clear this up.
There is no difference between adjusting screen refresh rate to content or not.
Server Version#: 4.100.1
Player Version#: 8.13-8.15
Problematic:
General
Format : Matroska
Format version : Version 4
File size : 11.6 GiB
Duration : 1 h 46 min
Overall bit rate : 15.5 Mb/s
Encoded date : UTC 2022-05-18 08:01:24
Writing application : mkvmerge v67.0.0 ('Under Stars') 64-bit
Writing library : libebml v1.4.2 + libmatroska v1.6.4
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5@Main
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 1 h 44 min
Bit rate : 15.1 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.076
Stream size : 11.0 GiB (95%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1634 cd/m2
Maximum Frame-Average Light Level : 109 cd/m2
Audio
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Commercial name : Dolby Digital Plus with Dolby Atmos
Codec ID : A_EAC3
Bit rate mode : Constant
Bit rate : 768 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 586 MiB (5%)
Title : DDP Atmos 5.1
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Complexity index : 16
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
General
Format : Matroska
File size : 7.20 GiB
Duration : 55 min 15 s
Overall bit rate : 18.7 Mb/s
Encoded date : UTC 2022-10-31 02:31:49
Writing application : mkvmerge v71.1.0 ('Fortitude') 64-bit
Writing library : libebml v1.4.4 + libmatroska v1.7.1
Video
Format : HEVC
Format profile : Main 10@L5.1@Main
Bit rate : 18.5 Mb/s
Frame rate : 25.000 FPS
Standard : Component
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.089
Stream size : 7.13 GiB (99%)
Language : English
Default : Yes
Forced : No
Transfer characteristics : BT.2020 (10-bit)
transfer_characteristics_Original : HLG / BT.2020 (10-bit)
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Bit rate : 192 kb/s
Channel(s) : 2 channels
Frame rate : 46.875 FPS (1024 SPF)
Stream size : 74.9 MiB (1%)
Language : English
Default : Yes
Forced : No
No issue with these:
General
Format : Matroska
File size : 19.0 GiB
Duration : 1 h 47 min
Overall bit rate : 25.4 Mb/s
Writing application : mkvmerge v72.0.0 ('Minuano (Six-eight)') 64-bit
Video
Format : HEVC
Format profile : Main 10@L5@High
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Bit rate : 24.6 Mb/s
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.124
Stream size : 18.4 GiB (97%)
Language : English
Default : Yes
Forced : No
Maximum Content Light Level : 449 cd/m2
Maximum Frame-Average Light Level : 119 cd/m2
Audio
Format : E-AC-3 JOC
Codec ID : A_EAC3
Bit rate : 768 kb/s
Delay relative to video : 83 ms
Stream size : 588 MiB (3%)
Language : English
Default : Yes
Forced : No
General
Format : Matroska
File size : 13.3 GiB
Overall bit rate : 17.8 Mb/s
Movie name : Telly
Encoded date : UTC 2022-05-10 06:36:35
Writing application : mkvmerge v63.0.0 ('Everything') 64-bit
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Color space : YUV
Bit depth : 10 bits
Stream size : 11.3 GiB (85%)
Default : Yes
Forced : No
Color range : Full
Audio #1
Format : E-AC-3 JOC
Codec ID : A_EAC3
Bit rate : 768 kb/s
Stream size : 586 MiB (4%)
Title : English
Language : English
Default : No
Forced : No
