Hi guys, I'm streaming movies from a Windows PC to my ATV.
Usually all goes ok but some movies are lagging.
How it goes depends on the movie itself.
Some movies seem to run ok, but they won't load subtitles. If I change settings to force encode, subtitles will load but the movie will stop every 5 seconds or so.
Here's the info of one of those
Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 1.95 GiB Duration : 2h 12mn Overall bit rate mode : Variable Overall bit rate : 2 110 Kbps Encoded date : UTC 2013-08-26 12:03:02 Tagged date : UTC 2013-08-26 12:03:02Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 2h 12mn
Bit rate : 2 012 Kbps
Maximum bit rate : 16.4 Mbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.055
Stream size : 1.86 GiB (95%)
Writing library : x264 core 132 r2 76a5c3a
Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=36 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=2012 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=31250 / vbv_bufsize=31250 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Tagged date : UTC 2013-08-26 12:03:17
Color primaries : BT.709
Matrix coefficients : BT.709Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 2h 12mn
Bit rate mode : Variable
Bit rate : 93.7 Kbps
Maximum bit rate : 104 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 88.5 MiB (4%)
Language : English
Encoded date : UTC 2013-08-26 12:03:15
Other are running ok with subtitles withou force encoding but, at some point of the movie, they just start lagging like the case before.
Here's the info on one of those medias
Format : Matroska
Format version : Version 2
File size : 5.46 GiB
Duration : 1h 55mn
Overall bit rate : 6 763 Kbps
Encoded date : UTC 2012-11-04 11:12:53
Writing application : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep 2 2012 15:37:04
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 55mn
Bit rate : 5 257 Kbps
Width : 1 280 pixels
Height : 696 pixels
Display aspect ratio : 1.85:1
Frame rate : 24.000 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.246
Stream size : 4.13 GiB (76%)
Writing library : x264 core 128 r2216 198a7ea
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5257 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : French
Default : Yes
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 1h 55mn
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Bit depth : 24 bits
Stream size : 1.22 GiB (22%)
Title : DTS 5.1
Language : French
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : Forced
Language : French
Default : Yes
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:09:53.792 : en:00:09:53.792
00:18:45.708 : en:00:18:45.708
00:31:17.833 : en:00:31:17.833
00:41:49.708 : en:00:41:49.708
00:52:06.042 : en:00:52:06.042
01:02:09.833 : en:01:02:09.833
01:11:20.917 : en:01:11:20.917
01:22:57.417 : en:01:22:57.417
01:32:01.542 : en:01:32:01.542
01:42:51.833 : en:01:42:51.833
01:50:48.500 : en:01:50:48.500
I don't recall any lagging on files which are not using subtitles. That makes me think it might be my server running out of memory or processing. My PC is quite ok, though. It's a i7 with 8GB of RAM and plenty of space.
Do you guys have any tips on how could I find out the issue and fix it?
Thanks a lot!
