Server Version#: Latest
Player Version#: n/a
Some photos were turned 90 degrees in the source files. Creating a library from the source photos still contain the rotated photos. I corrected the source photos to be oriented correctly. Tried rescanning the libraries but the photos stay rotated 90 degrees in the Plex library. Do I have to delete the entire library in Plex and add the same library again to correct the photos.
You might try just moving the affected photo(s) out of the folder Plex is monitoring, have Plex scan the files (so it removes them from the library), then put them back and re-scan again.
will try. I already rotated the photos in the source file. Have to compare the files in Plex library to see which ones are still rotated and move them out of the source file and do your suggestion. Thanks for the help.
OK. I have a strange one. I deleted the library from Plex that had photos with photos rotated. I corrected the original files to correct orientation. Add a new library with the corrected files. On the Plex server, I have one copy of the photos in the library. On a windows Plex Reader, I have one copy of the photos in the library. On my Android cell phone, I have duplicate photos on the added library. I have cleared the cache in Android for the Plex App, Have uninstalled the Plex app and reinstalled. Same problem, duplicate photos in the new added library. I even installed Plex on a Android tablet that never had Plex. Same problem. Is the Plex server putting out duplicate photos to the Android device and not to Windows 10 app? I have optimized the database, rescanned the library’s. Can not get rid of the dup photos. Any ideas? Thanks
