Server Version#:Version 4.158.0
Im getting the above error when going to Movies then Library. TV –> Library works fine, but Movies is erroring. Ive rescanned, cleaned trash, optimized DB, nothing seems to work.
Settings - Plex Web - ‘Show Advanced’ - Debug - “Restore Defaults”
this will reset the whole Web app and its settings. Afterwards, you may have to adjust which libraries are pinned to the left sidebar again.
https://support.plex.tv/articles/customizing-plex-web/
If that doesn’t help, you may have to repair your server database.
- stop your Plex server using the Plex icon in your Windows task tray, check the Windows Task Manager to ensure there are no Plex processes still running.
- run this .bat file: https://github.com/ChuckPa/DBRepair/tree/master/Windows
- restart Plex server using the regular Windows Start menu
Settings - Plex Web - ‘Show Advanced’ - Debug - “Restore Defaults” did the trick! THanks
