"Something went wrong" for all libraries
Server Version#: 1.28.0.5973
Player Version#: Web - 4.84.1
I’ve lost all my local directories on my Plex server. Not exactly sure when this happened, but it is within the last week. I’ve checked to see if my database is corrupt and it is not. I have server logs and can upload them if necessary.
Nothing has changed locally on my computer and all local folders are accessible and files play with no errors.
Inspect the plex media info of some library items.
Look at the drive letters and folder names under which Plex is expecting your files to find.
Then compare that to the drive letters and folder names under which you are actually seeing those files.
I have no items in my library whatsoever, so I cannot look at their media info.
Take a look into the task tray and see if the Plex server is running at all.
If you see it, right click on it and “Exit”. Wait a few seconds, then start it again with the Start menu. Refresh the web browser and see if the error persists.
I’ve done that multiple times, along with rebooting the PC it is running on. No change.
Grab the server logs (the “manual” way, zip the whole folder please)
I have them.
Plex Media Server Logs_2022-07-18_10-06-36.zip (3.6 MB)
You will have to repair your database.
Jul 18, 2022 10:00:51.963 [14044] ERROR - SQLITE3:0x23309579, 11, database corruption at line 88814 of [1b256d97b5]
Jul 18, 2022 10:00:51.963 [14044] ERROR - SQLITE3:0x23309579, 11, statement aborts at 16: [update media_parts set created_at = iif(typeof(created_at) in ('integer', 'real'), created_at, strftime('%s', created_at, 'utc')), updated_at = iif(typeof(updated_at) in ('integer', 'r
Jul 18, 2022 10:00:51.963 [14044] ERROR - Exception inside transaction (inside=1) (E:\jenkins\server\3582333205\Library\DatabaseMigrations.cpp:295): sqlite3_statement_backend::loadOne: database disk image is malformed
Jul 18, 2022 10:00:51.967 [14044] ERROR - Exception thrown during migrations, aborting: sqlite3_statement_backend::loadOne: database disk image is malformed
After you have it up and running again, please disable the “verbose” logging and leave only “debug” logging activated.
