Considering Leaving PLEX
Server Version#: 1.23.1.4602
I"m running MAC OS 11.4 off of 2 external drives both of which work fine, my iTunes libraries see them fine.
Since the last 2 Server Updates I can’t see my TV Shows directories and Plex no longer updates the other directories as well.
I can’t delete or even manage my libraries from the web portal on any web browser either.
Do I completely delete my account and start over or what?
Check your system for database corruption:
Thank you so much. This is exactly what I needed.
Re-creating my libraries now.
Again, THANK YOU!!!
If you have set up a backup directory, you may have been able to use a previous backup.
Then checked for Database Corruption and repaired if required. All you need then is to run a Library Scan.
Then again a clean install can be beneficial with so many updates these days.
Thanks so much for your help, this is exactly what i needed to do.
My library has just finished rebuilding and scanning. :slight_smile:
