Something with DVR causing Plex to crash on startup
Server Version#: v1.23.2.4656-85f0adf5b
Player Version#: N/A
Tuner Make/Model: HDHomeRun CONNECT
Guide/Lineup name: N/A, tried changing it
Using XMLTV?: NO
Channel number/Name: N/A
Server crashes on startup.
I am pretty sure I was adding a DVR schedule when it first occurred. One of my DVR schedules was missing so I re-added it, causing a crash.
The server does run for a few seconds, if I get in and delete the DVR completely, Plex runs normally. When I re-add the DVR and after it downloads the guide, the same thing occurs.
Attaching logs that should be relevant.
Plex Crash Logs.zip (18.1 KB)
Can someone tell me how to wipe my DVR schedule completely? I think I need to start my DVR from scratch to get it not to crash when I enable it now. Something must be held over between removing and re-adding.
Still can’t access the DVR, would rather not start from scratch. Requesting support.
Upgrade to 1.23.3.4707.
Delete your DVR.
Stop Plex
Navigate to C:\Users\Administrator\AppData\Local\Plex Media Server\Plug-in Support\Databases\
Delete the 3 files that begin with tv.plex.providers.epg
Restart Plex
Add DVR
If it crashes after this, remove any sports related scheduled recordings.
Looks like I had already deleted those files.
Re-adding the DVR and then quickly deleting every scheduled recording from the UI before it crashed seems to have resolved my issue.
Thanks!
