Sonic Adventure "Can't Start Playback"
Seems like a cool idea but not having any luck actually using it. It says “can’t start playback” no matter which songs I pick. I am on Plexamp, Android 12, currently in a drive thru line on 4G. Do I need to be on Wifi?
EDIT: tried it at home in front of the console and I get error: LPE: invalid url: library://x/item/%2Flibrary%2Fmetadata%2F%3FincludeSharedContent%3D1%26maxDegreesOfSeparation%3D-1
My server is Docker on Synology.
Server Version#: 1.25.0.5246
Player Version#: 3.8.2
how many tracks in your library? other sonic features work well?
Not in front of it but 25,000ish. Yes the other features work (quite nicely, I might add).
The only other thing is I might have stopped Plex and sql updated the database to put in my readings and play counts last week… :sweat_smile: I did it the right way though, with the --sqlite option to Plex Media Server.
that should be enough. i know there’s a bug around not displaying an error when it can’t find a path, have you tried two different and similar tracks? server logs would probably help as well (although i can’t look for a few weeks as i’m traveling)
Plex Media Server Logs_2021-11-27_22-41-23.zip (2.1 MB)
Logs attached. I just ran a failed Sonic Adventure (for 2 tracks from the same album) so there should be some data there at the end of the file.
just reporting back, not sure if it is a Plexamp update or a PMS update, but this feature is working now. Thanks
Oh glad to hear! And so sorry for not replying earlier.
