Unable to start media playback - Plexamp for iOS
Hi there,
it appears recently, presumably overnight that i can no longer start media playback via Plexamp for iOS? this appears to happen for my iPad/iPhone, and my partners iPhone.
When a track/album is selected a prompt appears “Couldnt Start Playback” with a never-ending spinning wheel.
Once i download the media, this works no issues which i find quite strange.
Plex is run through docker using the following repo: plexinc/pms-docker:beta
currently on PMS 1.42.2.10102
Plex Media Server Logs_2025-08-30_19-12-26.zip (4.7 MB)
Plexamp-Logs-2025-08-30-1 (1).zip (106.9 KB)
The server is barfing the request to start a play queue:
Aug 30, 2025 19:01:07.818 [Javascript] INFO - Error loading: post https://192-168-1-15.f9355c895088482e8c6d2653e555f0e0.plex.direct:32400/playQueues?includeLoudnessRamps=1&uri=server%3A%2F%2F2886678d2431d98037987f09e5bae3d2377101e9%2Fcom.plexapp.plugins.library%2Flibrary%2Fsections%2F14%2Fstations%2F3%2F190385%2Fe9e9d2c0-a54a-4db8-8270-e14554a52d86%3FincludeSharedContent%3D1%26maxDegreesOfSeparation%3D-1&shuffle=0&type=audio&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone: HTTP status 500
Here’s the error on the server:
Aug 30, 2025 19:09:48.712 [22472585743160] DEBUG - [Req#aaf36] PlayQueue: Converted 'server://2886678d2431d98037987f09e5bae3d2377101e9/com.plexapp.plugins.library/library/metadata/190385' to 'library://x/item/%2Flibrary%2Fmetadata%2F190385'
Aug 30, 2025 19:09:48.714 [22472585743160] DEBUG - [Req#aaf36] PlayQueue: Start index: 0 End index: 22 Count: 23
Aug 30, 2025 19:09:48.715 [22472585743160] ERROR - Got exception from request handler: std::exception
Aug 30, 2025 19:09:48.715 [22472790436664] DEBUG - Completed: [192.168.1.68:53047] 500 POST /playQueues?includeLoudnessRamps=1&uri=server%3A%2F%2F2886678d2431d98037987f09e5bae3d2377101e9%2Fcom.plexapp.plugins.library%2Flibrary%2Fmetadata%2F190385&key=%2Flibrary%2Fmetadata%2F190386&shuffle=0&type=audio&includeFields=thumbBlurHash (78 live) #aaf36 TLS GZIP 3ms 405 bytes (pipelined: 23)
You seem to be running the very latest server, not sure if related to the update?
(It looks like that might be the beta? If so try returning to stable and see if it helps)
Hi Elan,
thanks for the prompt reply!
after rolling back from beta to public (1.42.1.10060) I appear to still be able to reproduce the issu across all 3 devices.
Plexamp-Logs-2025-08-31-1.zip (131.4 KB)
Plex Media Server Logs_2025-08-31_08-54-46.zip (4.2 MB)
Sooo,
for some random reason this started to affect all media players and all media types.
Database was not ‘unhealthy’ but a full repair was done.
still no luck,
Deleted the docker, its appdata files, generated a new claim, and all media players are working as intended. My server will be busy for the next week re-syncing 80TB’s worth of media
