Sonic analysis stopped running on new tracks with v1.41.3.9232
Server Version#: 1.41.3.9232
Player Version#: 4.142.1
MacOSX version: 13.7.1,
Plex Media Server v1.41.3.9232-434341a9d - Apple iMac18,3 x86_64 - build: darwin-x86_64 macos - GMT 11:00
Sonic analysis now skips straight to rebuilding database even though I’ve added new tracks. Trying to figure out if its a specific track causing this but it has only begun happening with v1.41.3.9232 and oddly it seems to process new tracks ok overnight - but not as it used to do on a new scan. No settings have been changed.
There are a bunch of warnings in the logs in this format - how do i determine what the relevant filename is?
[MusicAnalysis] Analysis had wrong number of dimensions (1) for track 556248, skipping.
[MusicAnalysis] Analysis had wrong number of dimensions (1) for track 556251, skipping.
etc
All newly added tracks play fine so dont seem to be encoding errors - just that Sonic Analysis doesn’t run on them.
Experienced the same issue. New albums added, but no sonic analysis was performed.
Server: Version 1.41.3.9232
Mac OS
[MusicAnalysis] Analysis had wrong number of dimensions (1) for track 232759, skipping.
[MusicAnalysis] Analysis had wrong number of dimensions (1) for track 232760, skipping.
This is happening to me too on Windows server. Just posted logs in this thread. Same behavior, scan picks up the album and matches it but the Sonic Analysis step just doesn’t happen.
Issue remains on V1.41.3.9276
Sonic analysis happens fine as a scheduled task overnight - but always now excludes the most recently added album.
Eg If five new albums added during the day then none will be analyzed on addition (they used to be) but then four of the five will be analyzed overnight as part of a scheduled task.
It is a strange issue!
Same issue. M1 Mac Mini running Sonoma 14.7.1. I have Sonic Analysis enabled, and set to run ‘as a scheduled task and when media is added.’ 1.41.2.9200-c6bbc1b53 is the last version of Plex Media server for Mac where Sonic Analysis works. It does not appear to be working in 1.41.3.9232-434341a9d and 1.41.3.9276-8f15273fb.
Yes same here. Looks like the new albums were analyzed overnight but fail when first added.
It tries, but fails.
Just tested with today’s beta server 1.41.3.9292 and Sonic analysis is working again for new albums.
Thanks Dev team!
