Server Version#: 1.24.2.4973
Windows 10 OS Build: 19043.1237Plex Media Server.zip (544.3 KB)
My sonic analysis processed all my (about 6,400) albums for about 2 weeks and finished up. Four albums did not process correctly so I replaced them, and after this the logs say that the music analysis processing and indexing is finished, since about 10 days.
But I have yet to see any indication that this feature is activated at all in Plexamp (Android, v3.7.1 - no sonically related tracks or albums like in the blog post, no new related playlists are showing) or in the Plex web interface (random album > metadata-related albums are showing, but no sonically related albums). You’d think it would find some sonically related tracks with about 65,000 tracks analyzed.
Is there some way I can see that the sonic analysis is “switched on” correctly on the server? Music library advanced settings has “Sonic analysis” checked.
Take a look into the Plex data folder, and there into the subfolders Plug-in Support\Databases
Is there a subfolder present, named like Music Analysis n?
Try the latest beta server version. It contains an important bugfix regarding albums where analysis failed.
If your server was rudely interrupted while performing the sonic analysis, you might have to delete this Music Analysis n folder (while the server is not running).
Yes. I upgraded to beta version 1.24.3.5033-757abe6b4 and the same thing happens. The folder “Music Analysis 6 (processing)” reproduces itself after music scan and sonic analysis index completed.
I checked Plexamp and now I get the “On this day” as a new feature on start page (yay, a little progress!), but nothing else really.
Gonna wait this one out and see if this will fix it.
EDIT: Seemed to be a dud. Back to square one.
Thanks @OttoKerner for all the suggestions. If you come up with anything else for me to try, I’m all ears.
We’ve improved the logging around the process for the next release (or the one after), but it looks like at least one of the indexes is running into errors building.
The only reason I’ve seen for this in the past is that the disk didn’t have enough free space, is that a possibility here? Otherwise we’ll have to wait to get a more detailed error message in the next release.
Hi i’m having a similar issue . I have over 18000 albums and after a couple of weeks of sonic analysis my pc had an issue where windows file explorer started to close down , so had to do a reboot and now sonic analysis wont progress past 4135 albums. I can see that it is not processing anything as the cpu usage is 20% at most even though it shows sonic analysis is in progress . I have more than 50gb free and i dont have that folder in plugins suport/databases . Ive tried a few times to restart the process a few time but no luck
It’ll kick off every night or after every scan ends, depending on the setting, and pick up where it left off.
If it’s taking up CPU then it’s working (maybe it’s “stuck” on a particularly large album?). Without logs it’s impossible to say what you’re running into.
@elan I was thinking more along the lines if there is an easy way to redo everything from scratch - remove the current sonic analysis database fields and do a whole new scan.
But first I think I’ll wait for the new Plex server version with extended analysis logging and see where that takes me.
@elan - I have upgraded server to version 1.24.5.5173. Are there any improvements in logging I can try in this version to see what goes wrong while building the indices?
hmm, errno 9 would seem to indicate it had trouble opening and index file or writing to it. those files live in the same directory as the database files, in a subdirectory named for the library ID. i’m not i have any idea of why it’s failing, perhaps you have some knowledge of your setup and permissions?
