Sonos Not Connecting to Plex Media Server
Server Version#: 1.24.5.5173
HI,
I have a Synology with DSM7, manually upgraded to the above server version. Plex works when streaming music (flac format) on the web client but does not work with sonos. I can browe the library but when I try to play music it gives the following error
Sunday, November 7, 2021 - 8:18 AM Eastern Time
Unable to play ‘Still’ - the connection to Plex was lost.
port forwarding for the server is setup correctly and I can play songs outside of my network.
Sonos client is S2 and is the lastest version.
When I try to play from Sonos, plex console lists the following error:
[Transcode] Streaming Resource: Bandwidth exceeded: 2147483647 kbps > 80000 kbps
[Transcode] Streaming Resource: Reached Decision id=120962 codes=(MDE=3001,Cannot direct play this item. Required bandwidth is not known and only kbps is available. General=1000,Direct play OK. Direct Play=1000,Direct play OK.) media=(id=112865 part=(id=112865 decision=direct play protocol=http streams=(Audio=(id=295676 decision= channels=2 rate=44100))))
Bump.
I’m seeing this too. Several other threads mentioning the same issue. Please fix it Plex!
I too am using Synology with DSM7 and getting the connection was lost error message. If I try multiple times it usually starts to play, the connection was lost message usually pops up even with it playing. Sometimes I do random play and it fails but just selecting play will sometimes start the random play mode. Once it starts to play I have no problems.
Exactly the same issue since early this year. Combo DSM7 with Plex on Sonos won’t play FLAC files giving the error ‘connection to Plex was lost’. MP3-files play without any issue.
Playing from my computer on the Plex web-interface, the FLAC files play without any issue.
Just upgraded Plex to latest package (1.25.2.5319-7000) without any improvements :frowning:
Please Plex, how come this issue still is not resolved.?
Yep, I’m unable to play via my Sonos S1s too. In the Plex apps, it just skips, nothing obvious in the logs. If I watch the Sonos app while attempting to play I can see an error about connecting via IPADDRSSS.PORT.RANDOM.direct.plex (something similar at least) Remote access works fine, I double checked anyway just to be safe. I can play from Plex via the Sonos app and other devices can stream to Sonos fine. I’ve also disconnected and authorised the app.
Tagging @anon18523487 (A quick glance shows you were the last employee to respond to a Sonos issue)
What client are you having issues using? Please provide logs from that after reproducing the issue.
It was plexamp mainly, however it was failing from all apps when I tried. I have just been playing around and disabling secure connections seems to have stopped the issue. Digging in deeper, I have disabled DNS rebinding on my firewall (opnsense) and re-enabled secure connections. It seems to be playing now, but they are in an outbuilding and I’m putting the kids to bed so I can’t actually hear it to check at the moment :man_facepalming:.
If it is the rebinding issue that’s odd as I’ve never changed that setting, it’s just been left as the default. I’ll need to look into a little more. Sorry about the possible false alarm, I check more once I’m able to. Thanks.
I have just updated to 1.25.6.5577 on my Synology NAS and I can’t get Shuffle All in my Sonos app to work at all. Same with both the Windows app and the Android app. Before it usually worked after several tries but now, I keep getting a message that the connection was lost. Before I sometimes would get the connection was lost message, but it would still start to play.
Can you reproduce the error then grab the Android logs and the server logs.
Plex Media Server Logs_2022-02-23_10-53-24.zip (4.5 MB)
How do you redirect the Sonos App logs to my computer so that I can send them? Remember I am trying to get the Plex Shuffle command to work in the Sonos Windows app or the Sonos Windows App.
I have more success getting it to work when there isn’t any disk activity on the NAS.
From time to time the Shuffle playback will stop with the error message that the connection to Plex was lost, that is when I do get it working.
Oh you’re trying from the Sonos app. I thought you were using the Plex apps too. I have no idea how to get logs from the Sonos apps. Let me see if your server shows anything.
More Information
I have better luck getting the Shuffle All command to work if I select Shuffle All and then play now, I then get the connection was lost error message, I then use the play command and sometimes it starts to play, otherwise I repeat over and over until it does start to play.
Once I get it playing it almost always continues to work. I can pause and restart and it just works.
If I have the Sonos app open on my computer I sometimes get a message about 15 seconds before a tune ends that the next tune can’t be played and the connection to Plex has been lost. This may continue listing different tunes every two seconds until a tune is found that can be played. If no new tune is found before the playback is finished everything stops.
I have a Synology NAS running v7.
