Server Version#:1.22.3.4523-d0ce30438
Player Version#: 6.7.28.7055
Plex Media Server Logs_2021-06-18_12-37-35.zip (4.1 MB)
Sounds like everything is under water, like there is a sync issue with the receiver, the sound pulses on and off quickly. Higher volume passages sound like sonic mud. Similar to the AAC problem. Tested in DLNA mode using Roku Media Player and the problem is not there when playing the same file.via dlna.
