Spining Orange Circle Across Multiple Devices
Server Version#: 1.26.1.5798
Player Version#: 4.76.1
Plex Media Server Logs_2022-09-06_15-03-07.zip (6.7 MB)
Please can someone advise where I should be looking in these logs.
Recently I’ve started getting it hang, only way to get it back is to reselect the episode and hit resume from the last place, but its now happening so frequently its getting pretty unwatchable, logs look barren as I’ve pulled a fresh docker in but retained the original config, within the first minute or so of watching it started the spinning circle again.
I’ve tried a fresh docker (retaining the config) optimize database, clear bundles, empty the trash, moved the transcoding to ram. Shouldnt ever need to transcode more than 2 streams but its struggling to do one, machine is a 2600x with 32GB ram, shows are on regular hdd, config on NVMe SSD
For those with this issue make sure you’re running 1.27 or later as this solves the issue
For those on docker change the rep from plexinc/pms-docker or plexinc/pms-docker:plexpass as simply setting the version (variable 4) to plexpass using the default docker url stopped updating quite some time ago
