Spinning wheel when trying to watch some shows
Server Version#: 1.21.1.3876
Player Version#: 4.4.92
Recently downloaded a show and i get nothing but a spinning wheel when trying to play it, other files work just fine and when i play it directly on my windows box it plays just fine.
I have tried to play it at 2:52pm on 01/12 in log files
Below is an excerpt on what i think is the primary issue in the logs
Jan 12, 2021 14:52:31.362 [0x14b742ff7700] INFO - [Transcode] CodecManager: starting EAE at “/tmp/pms-8e6ef33a-6848-4f7f-ae40-e56b4aff90e8/EasyAudioEncoder”
Jan 12, 2021 14:52:33.999 [0x14b741fef700] ERROR - Error issuing curl_easy_perform(handle): 7
Jan 12, 2021 14:52:33.999 [0x14b741bed700] ERROR - Error issuing curl_easy_perform(handle): 7
Jan 12, 2021 14:52:33.999 [0x14b741fef700] WARN - HTTP error requesting GET https://192-168-1-206.046635a297e7497a93eae412276b64e9.plex.direct:32400 (7, Couldn’t connect to server) (Failed to connect to 192-168-1-206.046635a297e7497a93eae412276b64e9.plex.direct port 32400: No route to host)
Jan 12, 2021 14:52:33.999 [0x14b741bed700] WARN - HTTP error requesting GET https://192-168-1-213.6b1d728359f7441bb025f54bb426e801.plex.direct:32400 (7, Couldn’t connect to server) (Failed to connect to 192-168-1-213.6b1d728359f7441bb025f54bb426e801.plex.direct port 32400: No route to host)
Jan 12, 2021 14:52:34.000 [0x14b742ff7700] ERROR - [Transcoder] [eac3_eae @ 0xb2a7c0] EAE timeout! EAE not running, or wrong folder? Could not read ‘/tmp/pms-8e6ef33a-6848-4f7f-ae40-e56b4aff90e8/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mwcij2kbaqnne3tenvnmtdzb_538-0-0.wav’
Jan 12, 2021 14:52:34.001 [0x14b7b4de6700] ERROR - [Transcoder] [eac3_eae @ 0xb2a7c0] error reading output
Jan 12, 2021 14:52:34.001 [0x14b7b49e4700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 12, 2021 14:52:34.549 [0x14b7421f0700] ERROR - Unknown metadata type:
Jan 12, 2021 14:52:37.000 [0x14b7b55ea700] ERROR - [Transcoder] [eac3_eae @ 0xb2a7c0] EAE timeout! EAE not running, or wrong folder? Could not read ‘/tmp/pms-8e6ef33a-6848-4f7f-ae40-e56b4aff90e8/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mwcij2kbaqnne3tenvnmtdzb_538-0-1.wav’
Jan 12, 2021 14:52:37.001 [0x14b742ff7700] ERROR - [Transcoder] [eac3_eae @ 0xb2a7c0] error reading output
Jan 12, 2021 14:52:37.001 [0x14b7435fa700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 12, 2021 14:52:37.071 [0x14b741bed700] ERROR - Error issuing curl_easy_perform(handle): 7
Jan 12, 2021 14:52:37.071 [0x14b741bed700] WARN - HTTP error requesting GET https://192-168-1-144.ad0a0a38b5d74416933b41bc954160db.plex.direct:32400 (7, Couldn’t connect to server) (Failed to connect to 192-168-1-144.ad0a0a38b5d74416933b41bc954160db.plex.direct port 32400: No route to host)
Jan 12, 2021 14:52:39.001 [0x14b7419ec700] ERROR - Error issuing curl_easy_perform(handle): 28
Jan 12, 2021 14:52:39.001 [0x14b741dee700] ERROR - Error issuing curl_easy_perform(handle): 28
Jan 12, 2021 14:52:40.000 [0x14b7437fb700] ERROR - [Transcoder] [eac3_eae @ 0xb2a7c0] EAE timeout! EAE not running, or wrong folder? Could not read ‘/tmp/pms-8e6ef33a-6848-4f7f-ae40-e56b4aff90e8/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mwcij2kbaqnne3tenvnmtdzb_538-0-2.wav’
Jan 12, 2021 14:52:40.001 [0x14b7433f9700] ERROR - [Transcoder] [eac3_eae @ 0xb2a7c0] error reading output
Jan 12, 2021 14:52:40.002 [0x14b7b4de6700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 12, 2021 14:52:43.000 [0x14b7b4de6700] ERROR - [Transcoder] [eac3_eae @ 0xb2a7c0] EAE timeout! EAE not running, or wrong folder? Could not read ‘/tmp/pms-8e6ef33a-6848-4f7f-ae40-e56b4aff90e8/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mwcij2kbaqnne3tenvnmtdzb_538-0-3.wav’
Jan 12, 2021 14:52:43.001 [0x14b743dfe700] ERROR - [Transcoder] [eac3_eae @ 0xb2a7c0] error reading output
Jan 12, 2021 14:52:43.001 [0x14b742ff7700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jan 12, 2021 14:52:44.000 [0x14b7b43e1700] WARN - Connection Tester: Error testing media server Alpha in 10000 ms.
Jan 12, 2021 14:52:44.080 [0x14b7b6ff7700] ERROR - Unknown metadata type:
Jan 12, 2021 14:52:46.000 [0x14b742ff7700] ERROR - [Transcoder] [eac3_eae @ 0xb2a7c0] EAE timeout! EAE not running, or wrong folder? Could not read ‘/tmp/pms-8e6ef33a-6848-4f7f-ae40-e56b4aff90e8/EasyAudioEncoder/Convert to WAV (to 8ch or less)/mwcij2kbaqnne3tenvnmtdzb_538-0-4.wav’
Jan 12, 2021 14:52:46.001 [0x14b7b55ea700] ERROR - [Transcoder] [eac3_eae @ 0xb2a7c0] error reading output
Jan 12, 2021 14:52:46.001 [0x14b7435fa700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Thanks for any help at allPlex Media Server Logs_2021-01-12_14-52-47.zip (3.7 MB)
I reviewed your logs.
  1. Please turn off VERBOSE
  2. Please turn on DEBUG and leave it on. It’s best for overall debugging purposes.
  3. Logs are fixed size meaning verbose limits the max elapsed time to about 2 minutes which isn’t enough for 99% of the cases.
  4. After settings & saving the logging options, Restart PMS
  5. Let sit 2 minutes then recreate the problem and attach the ZIP logs.
I suspect you’re running out of notify slots on the host.
Well after much drama with my docker going haywire etc etc it was in fact verbose limits… apparently i finally hit the magic number of folders. Thanks Chuck!
