Split transcoder?
Server Version#: 1.42.2.10102
Can someone explain how this works? If I have HW endcoding enabled for everything, will it check down to CPU if I put a limit on GPU encoding?
Will it use CPU encoding first, then switch to GPU encoding once max CPU encoding is reached?
Does it just do nothing if you have HW encoding enabled?
If your system supports hw-accelerated transcoding and it’s enabled in PMS, Plex will try to transcode using the hw-encoder (allowing up to the newly added threshold of parallel hw transcodes). If there’s more streams or streams with tracks your system cannot transcode using the GPU, it’ll fallback to the CPU (again… for up to the number of specified parallel transcodes).
Keep in mind that even if a video can be transcoded using your GPU, CPU transcoding might still happen for an audio transcode.
That’s kind of unfortunate, because I would want it to work the opposite way. I would rather it do CPU transcodes first because they are usually of higher quality than GPU transcodes.
Perhaps we need a toggle to prefer CPU or GPU transcodes.
@vertigo235
Which GPU are you using and what is the video bitrate ?
I ask because with newer iGPUs / external GPUs and sufficient video bitrate,
you can’t tell the difference unless transcoding down to less than 12 Mbps for 2160 (4-8 Mbps for 1080p)
What’s “newer” in this context? That would be interesting to know.
