SQL logic error or missing database
Hello,
I’ve just migrated my PMS v1.3.4 from a CentOS v7.3 to other CentOS v7.3 and when I try to optimize the database I’m getting this error:
Feb 28, 2017 10:13:12.590 [0x7f3890bfe700] ERROR - SQLITE3:0x10, 1, statement aborts at 33: [insert into fts4_tag_titles(rowid, tag) select id, tag from tags where tag_type in (1,4,6)] SQL logic error or missing database
Feb 28, 2017 10:13:12.592 [0x7f3890bfe700] ERROR - Exception inside transaction (inside=1) (…/Library/FullTextSearch.cpp:35): sqlite3_statement_backend::loadOne: SQL logic error or missing database
Feb 28, 2017 10:13:12.599 [0x7f3890bfe700] ERROR - Soci Exception handled: sqlite3_statement_backend::loadOne: SQL logic error or missing database
Except that everything is working fine but I’m unable to optimize the db.
Here are the steps performed till now:
PRAGMA integrity_check -> ok
dump on com.plexapp.plugins.library.db and loaded from the dumped file (removed also the *-shm and *-wal)
upgraded to PMS v1.4.2, same issue. Downgraded back to v1.3.4, same issue.
Any idea what is causing this ?
Thanks!
Perhaps you tried to copy the database file when the source and/or the destination Plex server was still running? If so, you copied a damaged database.
Try the restoration procedure for one of the database backups.
Thanks @OttoKerner . I’ve performed a mass update and I want to avoid restoring from backup.
Maybe I can find a quick fix for this.
Performed a database restore and the issue is fixed. I’ll scan it again to have ti accurate :slight_smile:
Thank you @OttoKerner !
Perform the repair again, just to be sure the damage is not already slumbering in there.
Here are updated commands for repairing the database
Linux
sqlite3 "$PLEX_HOME/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db"  "PRAGMA integrity_check"
sqlite3 "$PLEX_HOME/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db" .dump > dump.sql
mv  "$PLEX_HOME/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db" "$PLEX_HOME/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db.original"
sqlite3 "$PLEX_HOME/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db" < dump.sql
Already performed this and everything is ok. Thanks.
