Squeezelite player plugin
I'd like to have rasplex emulate a squeezebox and connect to my Logitech media server. Has anyone done this or thought about how to implement it? There's an xbmc add-on xsqueeze which does this.
Any info appreciated.
Did you search the forum, there are a few posts relating to this.
Rasplex doesn't do plugins, not even if you try to install one using the now defunct Confluence skin.
regards
I'm new to rasplex and not clear on the rasplex/ openelec/ plex/ xbmc channels/ plugins distinctions. Within plex/ rasplex I guess a way it might work would be if something like a squeezelite player was bundled as a channel. I'll look at channel development.
