Server Version#: 1.43.1.10611
My cert wont renew I guess I need to post here cause there is no way to contact support.
May 19, 2026 10:44:13.401 [140550574230328] DEBUG - CERT: Forcing refresh.
May 19, 2026 10:44:13.405 [140550574230328] DEBUG - CERT: Certificate expires soon, fetching a new one.
May 19, 2026 10:44:13.406 [140550574230328] DEBUG - [HCl#224b] HTTP requesting GET https://plex.tv/api/v2/devices/xxx/certificate/subject
May 19, 2026 10:44:13.523 [140550814972728] DEBUG - [HttpClient/HCl#224b] HTTP/1.1 (0.1s) 200 response from GET https://plex.tv/api/v2/devices/xxx/certificate/subject
May 19, 2026 10:44:13.657 [140550574230328] DEBUG - [HCl#224c] HTTP requesting PUT https://plex.tv/api/v2/devices/xx/certificate/csr?reason=expiring&invalidIn=-255189
May 19, 2026 10:44:13.710 [140550814972728] DEBUG - [HttpClient/HCl#224c] HTTP/1.1 (0.1s) 429 response from PUT https://plex.tv/api/v2/devices/xx/certificate/csr?reason=expiring&invalidIn=-255189 (reused)
May 19, 2026 10:44:13.710 [140550574230328] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
<errors>
<error code="1003" message="API rate limit exceeded" status="429"/>
</errors>
