SSL certificate reset
Can I please get a cert reset?
Server Version#: 1.43.2.10687
Jul 01, 2026 08:28:22.552 [125431093578552] DEBUG - CERT: Forcing refresh.
Jul 01, 2026 08:28:22.566 [125431093578552] DEBUG - CERT: Certificate expires soon, fetching a new one.
Jul 01, 2026 08:28:22.566 [125431093578552] DEBUG - [HCl#f4] HTTP requesting GET https://plex.tv/api/v2/devices/199fa0ade14f9ec3908768a44a58274918b8a966/certificate/subject
Jul 01, 2026 08:28:22.756 [125431099906872] DEBUG - [HttpClient/HCl#f4] HTTP/1.1 (0.2s) 200 response from GET https://plex.tv/api/v2/devices/199fa0ade14f9ec3908768a44a58274918b8a966/certificate/subject
Jul 01, 2026 08:28:22.824 [125431093578552] DEBUG - [HCl#f5] HTTP requesting PUT https://plex.tv/api/v2/devices/199fa0ade14f9ec3908768a44a58274918b8a966/certificate/csr?reason=expiring&invalidIn=-4107843
Jul 01, 2026 08:28:22.891 [125431099906872] DEBUG - [HttpClient/HCl#f5] HTTP/1.1 (0.1s) 429 response from PUT https://plex.tv/api/v2/devices/199fa0ade14f9ec3908768a44a58274918b8a966/certificate/csr?reason=expiring&invalidIn=-4107843 (reused)
Jul 01, 2026 08:28:22.891 [125431093578552] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429,
Done. Please stop and restart your server now.
i think i need a cert reset
local server page says remote access is good but app.plex.tv says cannot access securely
Just got home and restarted. Still seeing the same issue. Any other things I can try?
Can i get a cert reset too everything i sgreen but i cant access it on my own network everyone outside can
[mod edit: your certificate is brand new. So that’s most likely not the culprit. See Client says it won't play from "remote server", although the server is local for a few things to check. If there are more questions, please create your own forum thread. ]
Could I also get certificate reset? My Nvidia Shield TV server status is Indirect.
Thank you, Bret
[mod edit: Your issue looks exactly like this one: PMS can't acquire certificate — persistent "API rate limit exceeded" (429, code 1003) - #2 by OttoKerner ]
The Shield internal storage still has 3.5GB available so I don’t think that is the issue.
