Is anything being done to resolve the security vulnerabilities described in this post? I'm trying to replace the revoked SSL certs with some trusted ones of my own but Plex crashes upon any modification. Help!
Is there any way to forward this information directly to the development team? I love the application; however, I don't feel safe having Plex installed...yet alone having it accessible from the internet. Potential attackers could use the vulnerabilities to browse the local filesystem.
3. Unauthenticated information disclosure through stack traces
Python stack traces are included in the responses for some requests. This
allows an attacker to gain information about the target operating system,
local file paths etc. which can be used in further attacks.
Also, In the event anyone does not feel comfortable opening an unknown link here's the entire vulnerability report.
SEC Consult Vulnerability Lab Security Advisory < 20140411-0 >
title: Multiple vulnerabilities
product: Plex Media Server
vulnerable version: confirmed in 0.9.9.10
fixed version: none
impact: High
homepage: http://www.plex.tv
found: 2014-02-06
by: Stefan Viehböck
https://www.sec-consult.com
Vendor/product description:
"Plex is a media player system consisting of a player application with a
10-foot user interface and an associated media server. It is available for
Mac OS X, Linux, and Microsoft Windows."
URL: https://en.wikipedia.org/wiki/Plex_(software)
Vulnerability overview/description:
1. Use of plain text protocols
Plain text protocols are used in various places.
The Plex App Store fetches App listings and App code via HTTP. This enables
active attackers (MITM) to run code in the context of the Plex Media Server.
The Plex "Remote" functionality uses HTTP as well. This enables passive
attackers to gain access to the session token in order to access the Plex Media
Server web interface.
2. Insecure use of SSL/TLS
The Plex Media Server offers HTTPS access via TCP port 32443. The certificate
that is used is issued by "DigiCert Secure Server CA" which is a commonly
trusted certificate authority. The certificate is issued to "*.hub.plex.tv".
The private key for this certificate is included in the Plex software and can
be extracted easily.
The DNS server behind "hub.plex.tv" is configured to resolve subdomains
relative to the IP indicated in the name. Eg. 1-2-3-4.hub.plex.tv resolves
to the IP 1.2.3.4. This enables all Plex Media Servers to offer SSL/TLS
services out of the box without prior configuration and using a valid
certificate.
For this to work the corresponding private key has to be included in the
software. This enables active attackers to execute SSL MITM attacks as the
private key is effectively public.
This mechanism can be abused by malicious entities to provide services on
arbitrary IPs via SSL/TLS as well. One example would be to run a
watering-hole-style attack by abusing the reputation of the Plex domain as
well as the valid certificate.
As this mechanism requires the private key to be compromised it should not be
used in the first place. The certificate should be revoked.
Note:
The Plex Media Server seems to offer DHE ciphers (DHE_RSA). The perfect forward
secrecy (PFS) properties of these KEX ciphers would prevent passive attackers
from decrypting communication.
4. Cross Site Request Forgery
The application does not implement any kind of CSRF protection. Quite the
contrary, security mechanisms that would minimize the extent of CSRF attacks
are deliberately disabled. The Plex Media Server explicitly allows all
sources (wildcard) in cross-server resource sharing (CORS) as well as in
cross-domain policy restrictions (Flash and Silverlight). This enables
attackers to retrieve arbitrary content (eg. the master token) from the
server.
Proof of concept:
No proof of concept needed.
The Plex App store is located at: http://nine.plugins.plexapp.com
The private key for the "*.hub.plex.tv" certificate:
-----BEGIN RSA PRIVATE KEY-----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-----END RSA PRIVATE KEY-----
The following request causes an exception in the application logic.
GET /system/proxy HTTP/1.1
Host:
X-Plex-Url: http://my.plexapp.com/NONEXISTANT
A stack trace is included in the server's response:
HTTP/1.0 500 Internal Server Error
Content-Length: 3437
Content-Type: application/xml
Cache-Control: no-cache
X-Plex-Protocol: 1.0
<?xml version='1.0' encoding='utf-8'?>
Traceback (most recent call last):
File "C:\Users\user\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\components\runtime.py", line 845, in handle_request
result = f(**d)
File "C:\Program Files (x86)\Plex\Plex Media Server\python27.zip\urllib2.py", line 629, in http_error_302
return self.parent.open(new, timeout=req.timeout)
File "C:\Program Files (x86)\Plex\Plex Media Server\python27.zip\urllib2.py", line 410, in open
response = meth(req, response)
File "C:\Program Files (x86)\Plex\Plex Media Server\python27.zip\urllib2.py", line 523, in http_response
'http', request, response, code, msg, hdrs)
File "C:\Program Files (x86)\Plex\Plex Media Server\python27.zip\urllib2.py", line 448, in error
return self._call_chain(*args)
File "C:\Program Files (x86)\Plex\Plex Media Server\python27.zip\urllib2.py", line 382, in _call_chain
result = func(*args)
File "C:\Program Files (x86)\Plex\Plex Media Server\python27.zip\urllib2.py", line 531, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 404: Not Found
No CSRF tokens are implemented.
The files crossdomain.xml and clientaccesspolicy.xml in the webroot allow
both Silverlight and Flash to send arbitrary requests to the server and
receive responses.
Some pages respond with the "Access-Control-Allow-Origin: *" headers.
Vulnerable / tested versions:
The vulnerabilities have been verified to exist in Plex Media Server version
0.9.9.10.
Vendor contact timeline:
2014-02-09: Contacting vendor through elan@plexapp.com and requesting
encryption keys.
2014-02-10: Vendor provides encryption keys.
2014-02-10: Sending advisory and proof of concept exploit.
2014-02-10: Vendor acknowledges receipt of advisory.
2014-02-17: Requesting status update.
2014-02-21: Requesting clarification regarding fixed version.
2014-02-21: Vendors provides further information about reported vulnerabilities.
2014-02-24: Requesting clarification regarding patching status and setting
deadline (2014-03-24).
2014-02-25: Vendor announces that the certificate will be revoked soon.
2014-04-04: Requesting status update.
2014-04-05: Vendor confirms that certificate has been revoked. No other fixes
have been implemented.
2014-04-11: SEC Consult releases security advisory.
Solution:
No solution is available.
Workaround:
No workaround available.
Advisory URL:
https://www.sec-consult.com/en/Vulnerability-Lab/Advisories.htm
SEC Consult
Vienna - Bangkok - Frankfurt/Main - Montreal - Singapore - Vilnius
Headquarter:
Mooslackengasse 17, 1190 Vienna, Austria
Phone: +43 1 8903043 0
Fax: +43 1 8903043 15
Mail: research at sec-consult dot com
Web: https://www.sec-consult.com
Blog: http://blog.sec-consult.com
Twitter: https://twitter.com/sec_consult
Interested in working with the experts of SEC Consult?
Write to career@sec-consult.com
EOF Stefan Viehböck / @2014
That post only states they have updated the version of OpenSSL. However they have not re-engineered their method of using SSL not to include the private key in the package. From my understanding nothing was really fixed.
Correct. SSL is not ready for wide-spread use in Plex Media Server right now, almost no clients support it and it relied on a static key. We are looking into other options to make the media server SSL ready, the current implementation is a dead-end I would say.
Have you looking in to becoming your own CA? When a new server authenticates a unique private key could be generated and distributed to that machine. You would need quite a lot of server side processing power to generate all the keys but it could be done.
Also, until a solution is developed is there any way to replace the certs with my own? It crashes on every attempt. Is there some sort of hash check that prevents the package from running after modifications? Thanks for your reply!
We are looking into several approaches, but we have nothing to announce right now.
No there is no way to change the current certs, the current implementation is not good, I would not use it. If you are really paranoid about things like that I would look at VPN solutions instead.
Personally I’m not paranoid but 40 hours out of the week it’s my job to be. Best of luck solving this issue! Plex really is a great product!
