Stability issues 1.28.x on 64bit Linux
Server Version#: 1.28.0.5999 / 1.28.1.6018
Player Version#: 8.7 (iOS) + Plex web running on Plex Server
I have had repeated crashes after updating to 1.28.0.5999, and then after downloading 1.28.1.6018 from the Plex website, they continued.
Rolled back to 1.27.1.5916 with a manual install with dpkg over the top of 1.28.1 and it is stable again.
Crash dumps were uploaded to Plex automatically I think, however I wasn’t able to manually retrieve the files before the service automatically restarted.
Logs:
Aug 5 11:35:55 server Plex Media Server[3367821]: ****** PLEX MEDIA SERVER CRASHED, CRASH REPORT WRITTEN: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Crash Reports/1.28.0.5999-97678ded3/PLEX MEDIA SERVER/994e0c1e-6670-4bd2-c01e09b6-efe0d76e.dmp
Aug 5 11:37:28 server systemd[1]: plexmediaserver.service: Killing process 3367857 (Plex Script Hos) with signal SIGKILL.
… repeated …
Aug 5 11:37:28 server systemd[1]: plexmediaserver.service: Killing process 3368037 (Plex Script Hos) with signal SIGKILL.
Aug 5 11:37:34 server systemd[1]: Stopped Plex Media Server.
Aug 5 11:37:34 server systemd[1]: Starting Plex Media Server…
Aug 5 11:37:34 server systemd[1]: Started Plex Media Server.
Aug 5 11:38:54 server Plex Media Server[545772]: ****** PLEX MEDIA SERVER CRASHED, CRASH REPORT WRITTEN: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Crash Reports/1.28.0.5999-97678ded3/PLEX MEDIA SERVER/86044d1c-ef2b-43aa-15b83d83-35afec5e.dmp
Aug 5 11:40:25 server systemd[1]: plexmediaserver.service: Killing process 545812 (Plex Script Hos) with signal SIGKILL.
… repeated …
Aug 5 11:40:25 server systemd[1]: plexmediaserver.service: Killing process 545826 (Plex Script Hos) with signal SIGKILL.
Aug 5 11:40:30 server systemd[1]: Stopped Plex Media Server.
Aug 5 11:40:30 server systemd[1]: Starting Plex Media Server…
Aug 5 11:40:30 server systemd[1]: Started Plex Media Server.
1.27.1.5916 has been rock solid after rolling back.
Just back from 3 week holiday.
Noticed my Plex is no longer working. There have probably been several version updates since I use watchtower to update my docker images, so I don’t exactly know since what version it went wrong.
Only thing I’m seeing is lots of continuous errors like:
today at 21:51:36****** PLEX MEDIA SERVER CRASHED, CRASH REPORT WRITTEN: /config/Library/Application Support/Plex Media Server/Crash Reports/1.27.0.5897-3940636f2/PLEX MEDIA SERVER/edfeb1ca-0144-406b-d7779ab8-315d01a8.dmp
I see dmp being written, then it disappears. I have no other clue to what might be causing this.
Any clue to what may be causing this?
I have tried versions/tags 1.28.2, 1.28.1, 1.28.0, 1.27.1, 1.27.0, all causing the same crashes (corrupted library?)
Just did an update of my QNAP to latest firmware, which needed a restart.
After that Plex server was starting up and I could reclaim my server (after password change I had to do recently).
I guess the restart of the NAS would have done it. Still not clear from the logs though what the actual problem was.
