@trumpy81 said:
@abe_va said:
Awesome,
Downloading file bot right now, i have MANY tv shows that have episodes missing or are not reading in plex in the proper way, i have tried moving them into their own folders etc with no luck i hope filebot fixes them and plex can read them easily.
I hope you are aware that TV Shows must be named like so: TV Show Title - S01E01 - Episode Title.ext
TV Show Title is the name of the show in question EG: Arrow. S01 is the Season number and E01 is the episode number, these MUST be included in the file name. Episode Title is optional, but should be included. .ext is the extension of the file, EG: mp4, mkv, avi etc…
TV Shows must be organised like so:
Media
…|_ TV Shows
…|_ Arrow
…|_ Season 01
…|_ Arrow - S01E02 - Honor Thy Father.mp4
…|_ Season 02
…|_ Arrow - S02E13 - Heir To The Demon.mkv
I am a touch confused, its also been a long day and im recovering from surgery 4 days ago, but this kind of stuff keeps my mind busy and i love perfecting my media empire :)) So shall i dedicate an SSD of 128 GB for “plex data” currently my plex data or app data not sure if those are the same is a little over 9 GB, if so , how would one do this ? i understand the idea and concept but sadly i get lost during the steps and order.
If you want to dedicate an SSD to your Plex data, then you need stop Plex from running and then move the folder and it’s contents of C:\Users\YOUR USER NAME\AppData\Local\Plex Media Server to the new location.
You would then create a symlink using EG: D:\Plex Media Server as the source, and drop it in the C:\Users\YOUR USER NAME\AppData\Local folder as a Symbolic Link, using the program found here: Link Shell Extension and referenced in the article below rather than using mklink.
See this page: http://www.howtogeek.com/howto/16226/complete-guide-to-symbolic-links-symlinks-on-windows-or-linux/
Plex data or Plex metadata refer to the above location. Plex app data normally refers to a Plex client app data and is quite different. It can also mean several other things.
So plex will scan the new location the my new drives and rebuild metadata library, like how will it know about all the titles i had to go in and manually fix, will it know to add those fixes to my newly scanned media in the drive pool,.
If you made sure the padlock icon beside each field you edited turned orange and you clicked on the save changes button, you should be good, but note that Plex can and sometimes does override that, so you may find that some files need to be edited again. Hopefully, it will be less than a handful.
i currently have drivepool set to x2 duplication and one drive can fail without data loss, and i guess im just gonna use my external as a extra hard copy.
Good idea, and I am sure you are aware that if two drives fail, everything is toast. There is no replacement for backups.
Oh yes i see what u mean i think, the downloads will automatically be dumped into OUTSIDE folders that are NOT being scanned or assigned in plex, i will manually move them over once they are complete and THEN update library every time i get a decent batch of media added. does that make since now ? can i set my PLEX P drive as my default download except they will be dumped in a folder called “Newly added”.
Yes, your plan will work nicely.
i have my 275 GB SSD brand new sitting here, i still have not gotten to the point where i know how to clone my current windows to simply swap out the drives and not have to re-install or change anything, just a simple upgrade in capacity. is that possible ?
This is the 21st century, anything is possible :))
You will need to find a suitable imaging software, such as Paragon Hard Disk Manager, you would then create a restore disk on either a DVD or a USB pen drive using Paragon Hard Disk Manager.
Then you would turn off the PC and add the new drive, don’t replace any other drive, just add the new drive OK. Turn on the PC and make sure you boot it using the media you created above. Then you would ‘clone’ one drive to the other. You want an exact copy of your regular C:\drive copied to the new drive.
Assuming everything went well above, you would then turn off the PC, remove the OLD drive (do not wipe the old drive yet) and put the new drive in it’s place.
Now turn on the PC and let it boot, there should be no changes needed, Windows should handle it without intervention, and all should be good in the world.
If the worst happens and the PC fails to boot or is obviously screwed up, then turn off, put the old drive back in and try again, and keep your fingers crossed … :))
I will start working on renaming all my files with filebot as soon as i understand it a little better, problem is i already copied my entire library of media over to my new drivepool with all the titles that need fixing, so i might have to end up fixing everything twice … on drive pool and on external ? unless u know an easier less confusing way. Man im excited but at the same time i have alot of work ahead of me ! lol i hope it all goes as smoothly as you lay it out :)
Wow i just realized i have no more sata ports on my machine… so i probably cant do the ssd clone switch out thing we talked about cause i cant even plug it up sigh guess i should buy just some cheap 20 dollar sata controller card ? Amazon and newegg is where i order all my stuff.
