If so, then how or where can i use the official Plex Docker?
I just downloaded it with terminal, like apt-get install docker…
In which order, what exactly needs to be installed?
If i click on your link, i get to github. As i know i have first to install Docker.
But which Docker Version, as you said i’m not using the right one.
If i go here:
It says:
To get started with Plex Media Server in Docker start by installing Docker on your platform of choice - in other words, every Docker Version should work. So apt-get install docker should be fine, right?
After installing Docker, i need to create a working Configuration.
After Config just start the Docker by Docker start blabla and then run the Script again.
Am i right or did i miss something?
I found a tutorial here:
The Installation for Docker Engine:
Works fine from 1-5.
Installing now Plex for Docker, Point 1 works fine (sudo docker pull linuxserver/plex).
But creating the Config is not easy.
As i have PMS already running nativ on my Linux Server, i need to find out how exactly i have to build the Config for Docker Plex, to get Access to the Docker Plex, like the native Plex.
I think i have to use the Bridge Networking Mode.
And to seperate the 2nd Plex, i will need to set an another Port.
Because if i start Docker, i will get Errors.
From the Log (path: /home/docker/plex/config/Library/Application Support/Plex Media Server/Logs/)
Feb 01, 2019 21:02:28.773 [0x7fd19b24c840] ERROR - Error: Unable to set up server: listen: Address already in use (N5boost16exception_detail10clone_implINS0_19error_info_injectorINS_6system12system_errorEEEEE)
Here’s my Create:
docker run -d
–name=mediathek2
–restart=always
–network=host
-p 32401:32400/tcp
-e TZ=“Europe/Berlin”
-e PLEX_CLAIM=“claim-xxx”
-e ADVERTISE_IP=“http://127.0.0.1:32400/”
-v /home/docker/plex/config:/config
-v /path/to/my/local/stuff:/stuff
linuxserver/plex
No matter if try -p 32400:32401/tcp or -p 32401:32400/tcp. Or if i type the IP of the Server instead of 127.0.0.1, with :32401 or :32400.
I get always the same Error.
Hello.
Docker Plex runs now.
I had first to stop the native Plex.
I used this Config for the Create:
sudo docker create
–name=mediathek2
–restart=always
–network=host
-p 42400:32400/tcp
-e VERSION=latest
-e PUID=1001 -e PGID=1001
-e TZ=Europe/Berlin
-e PLEX_CLAIM=“claim-bla”
-e ADVERTISE_IP=“REAL.IP:42400”
-v /home/local/path/stuff:/stuff \
I set the Port 42400 in the Settings of Docker Plex. And in the native Plex i set it 32400.
The only Problem is, i cant use both Plex Instances. I think this has something to do with the Ports and/or Portforwarding.
Can someone help?
I’m so close to run both Instances.
