Hi, I have a Hp Microserver from powerup running weater uploads and Aircraft radar uploads. I need to have Plex start from bootup as the server does reboot as part of refreshing above etc. Win 10.
If this doesn’t have a option I need to cancel my pass as not fit for purpose. 1 day old. I bit the bullet and got this prog.
Regards
Siddy
You want to run Plex Server as a Windows system service
Ok I got it running but needed to use servername\username then it popped up for the password, ran it ok. Then logged on and it stalled so removed the start at logging tick and all ok.
Tested over mobile network as well.
Other couple of issues I have is playback of tracks with no gaps where music plays as one track normally and it’d would be good if this would rip and file your music.
Will do a search for these tit bits.
